F41 Battery usage of camera light sensor
(Topic created on: 12-29-2020 01:31 PM)
J271
Community Guidelines
Dears
For some reason, I see in Battery usage, the Cameralightsensor taking away too much of battery. It has been active in background. It is the highest consuming app on my mobile including those that i use. This happened overnight when phone was not being used for ~4 hours. It took about 8% battery. (I know numbers may not be too much but for a battery of this size, I dont know what is this app which is draining battery)
Can anyone tell me what is this and why is it happening ?
I applied all latest updates for F41
Anyone else with the same issue ?
Thanks
10 Comments
francaizsam
Find out the apps which consume battery a lot. Select the apps not to run in background and check those apps regularly. Thats all.
J271
Thats what I'm doing. It doesn't show System apps or things like On screen time consumption of battery etc. Any idea? It shows on Lenovo phones.
francaizsam
Then contact customer support or visit service center. In my A50, CameraLightSensor barely uses background data.
Turn off adaptive brightness and face lock.. (it will give some relief but no 100% solution for this)
J271
I turned off adaptive brightness and monitoring. Does this version not show how much battery is consumed by system apps or screen or wifi etc like it does in other mobile (Levovo) ? Any idea ?
Not exactly..wont show like how much battery wifi is consuming, but will show for camera light sensor and other similar system apps
Ehsank
if you don't want then you have to compromise with adaptive brightness
J271
Thank you. I'm happy to do so because I use a dark mode always. I wonder if there is some way for me to know how much does screen consume ?
Samsung_Support1
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
