03-17-2023 06:15 PM in
Community Guidelines
03-22-2023 07:43 PM in
Community GuidelinesDear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same and please follow the easy troubleshooting steps which might help to solve the issue.
Check space availability:
Is there sufficient space available on your device?
Kindly check the space on your device:
Path: Settings > Device Care >Storage
To improve the device performance there should be sufficient space. Request you to keep at least a ''minimum 20% internal memory free''.
Kindly check RAM in your device:-
Path: Settings>Device care>Memory.
To improve the performance RAM of the device should be free. So, clear the RAM memory once a day.
Check app cache
Does the device hang while accessing any particular Application/Game etc?
Please follow the below steps
1- Clear app cache through Device care:
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on Device care.
Step3: Tap on Storage.
Step4: Tap on CLEAN NOW.
Please visit this mentioned link to resolve your device issue: https://www.samsung.com/in/support/mobile-devices/how-to-prevent-the-overheating-of-your-galaxy-devi...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Warm regard,
