saadbin
09-25-2019 04:24 PM in
Bixby
Wanted to enquire about Bixby voice link running in the background which has been consuming over 30 percent of my battery on a daily basis, I don't see any option of deactivating it and its creating issues for me.
It wasn't present before it has started since day before.
Please advice.
2 Comments
Sidhabhi
09-25-2019 05:12 PM in
Bixby
Bro, force stop it..and disable all notifications and permissions
Settings>applications>select Bixby voice>force stop it>Turn off notifications>Disable "Appear on top">Disable Change system settings..
just give a try..
just give a try..
saadbin
09-25-2019 05:17 PM in
Bixby
did that, will check in a while if it's still consuming or not. will update you.
thanks
thanks
