Highlighted
good lock routines
1 easy to set the function
2 can set unlimited function
3 various modes are available
4 simple and very clean routines
5 works very accurately all the time
now worst part
1 lack of customisation
2 lack of various function like keyboard vibration timer, lack of edgelightining i.e its completely rigid to one type of edge lighting function.  lack of screen time out setting
3 difficulty in setting power-saving modes that is it does not have well accurate functionality to set power-saving modes that are it can't decide which power saving mode is to be applied it can by mistake apply the ultra power saving mode if not watched carefully
4 rigidity on the top level
Bixby routines
1 easy to set more complex functions
2 very much customizable in fact highly customisable
3 easy to set power-saving modes
4 has various edge lighting options
5 has a better quality of customisation
drawback
1 unlike good lock routines it is capped to 50 functions
2 s9 and note 9  devices do suffer that is some function like aod and auto-rotate suffers which isn't a big deal
3 lack of video enhancer setting unlike good lock routines the Bixby routines does not have the setting for the video enhancer off and on based on the apps
4 game mode lacks some details
these are the key differences between the Bixby routines and good lock routines
if you want to join
https://discord.gg/xHEpfTj
