Power button not working
(Topic created on: 12-08-2022 09:50 AM)
Shukla9426
Bixby
After Android update after Android 13 update power button is not working
7 Comments
amitkr9123
Bixby
Model ?
Shukla9426
Bixby
Samsung f62
amitkr9123
Bixby
Did you tried restarting once
Shukla9426
Bixby
Samsung F62
AAC10
Bixby
Go to settings and reassign side buttons.
Hardikp1258
Bixby
You need to change side key settings.
For that, just pull down the notification panel all the way down, click on power icon, now you will see all power off, restart options along with the button named side key settings at the bottom of the screen. Click on side key settings. Now you will see Press and hold options, in that select power off menu.
That's it!
cs_member8
Bixby
Dear Samsung Member,
We acknowledge your query and apologize for the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
