Resolved! Solved
Note 8 firmware
(Topic created on: 02-20-2021 06:18 PM)
Shoko
Bixby
My Bixby app says my note 8 needs a firmware update to android 9 to work properly, when I check updates on my phone it says latest updates are already installed on my phone. How can Samsung update applications and not the firmware on the gadget? This doesn't make sense to me.
Maps_sam07
Bixby
Hi Shoko
Kindly note that your device may need to booked in for a Software reload. It seems like the current software loaded on your device is malfunctioning. Please go to the below link to locate the closest Authorized Service Center to you.
https://www.samsung.com/za/support/service-centre/
3 Comments
Maps_sam07
Bixby
Hi Shoko
Brandons
Bixby
I can't upload my Samsung a31 firmware update.
Brandons
Bixby
any assist me please
