# Need help removing. # Media volume limit pin. I activate volume pin on A32
(Topic created on: 07-03-2023 06:10 AM)
The000
Bixby
8 Comments
Bixby
Follow what they are asking you to do to change the volume settings
The000
Bixby
I forgot the pin my brother, help please. With my earphones the I set is not a problem. The problem is that the volume protection thing applies when I connect with my Bluetooth sound system too! 🥺🥺 I didn't expect it to do that🫣😭😭😭😭
Bixby
If you forgot your pin your will have to factory reset your phone to factory default please remember your email password when doing a factory reset
The000
Bixby
Thanks bro. Is its safe though, will this not erase my photos or apps. Like things of importance to me?
Bixby
Unfortunately you will have to do a backup of your apps and photos and then do the factory reset but if you have forgot your pin your last option is to take your phone to your nearest Samsung service center for further assistance
The000
Bixby
Appreciate your help bro. Thank a lot..
grokkliki
Bixby
baby
The000
Bixby
Thank you 😊
