samsung galaxy s20plus edge screen eating battery in idle
(Topic created on: 09-03-2020 08:55 AM)
MDTarik
جالاكسى S
I purchased new samsung s20 plus i noticed that edge screen using too much battery
7 Comments
samsungksa1
جالاكسى S
Thank you for contacting Samsung KSA
Dear ,
you can follow the below steps to reduce battery draining:
battery consumption will increase when you use certain features or apps , such as GPS,games, or the internet
make sure that power saving mode is enabled
check the battery drainage for each app by going to settings-device care - battery
as you can put unused apps to sleep by going to settings-device care-battery-tap 3 dots -tap on sleeping apps -add the apps you want
if you still face the same issue then kindly visit the nearest service center
the link of the service centers :
https://www.samsung.com/sa_en/offer/service-centers/
MDTarik
جالاكسى S
when i browsing every 2 minutes 1% loss
samsungksa1
جالاكسى S
dear make sure to close all the apps in the background
and kindly visit the nearest service center in order to check the battery
MDTarik
جالاكسى S
where is the samsung service center in buraydah qassim?
samsungksa1
جالاكسى S
Dear you can visit the nearest Extra branch
as extra is one of our authorized service center
MDTarik
جالاكسى S
i purchased it from amazon sa
MDTarik
جالاكسى S
i read article on xda about s20 plus with exynos no one get more than 5 hours of sot time with 120hz and edge panel it's terrible battery life i don't think it's my phone problem samsung s20 series have terrible battery life with exynos version i did waste my money
