hey guys any problems in s7 /edge i will help only who know English can join
(Topic created on: 06-09-2017 05:23 PM)
IndianCommunity
جالاكسى S
Hey guys join my community and get latest s7 s6 and edge models problems solved
10 Comments
CR72
Beginner Level 3
جالاكسى S
yo i got s7 and i can't use it in ma sim card it just keeps asking pin network and i wonder what it is bruh any help
جالاكسى S
Where u bought that s7 ?
First u need to activate with the same country sim where you bought s7
جالاكسى S
And please join in my community
CR72
Beginner Level 3
جالاكسى S
after i activate it in there will i be able to use it with ma country sim
جالاكسى S
جالاكسى S
Yes cr7 you can activate or open these lock. First put the country sim into the phone where you bought it. Speak to someone from that sim for about five minutes then it will get automatically unlocked after then you can use your phone with any other country sim.
Danishmalik1
جالاكسى S
hi.. my s7 edge screen one greenhair line coming can you let me how iresolve thisproblem
جالاكسى S
This can be both software and hardware problem too
Software problem-
I want to ask you first when the line appeared on your s7 edge. If it appeared after software update then you have to factory reset or downgrade you're mobile software.
Hardware- if your phone has been fallen down or bended your display will get affected then you have no chance to repair it you should give your phone to Samsung service.
Please join in my community.
Castrox
جالاكسى S
Hey !
I can't find emoji in my S7 edge ... help please !
