03-04-2024 02:09 PM (Last edited 03-04-2024 05:50 PM ) in
جالاكسى S- Mark as New
03-04-2024 03:05 PM in
جالاكسى SMake sure you have the latest version of the Android Auto app installed on your phone. Additionally, check if there are any firmware updates available for your car's infotainment system.
Android's battery optimization feature may sometimes interfere with Android Auto's ability to stay connected. To disable battery optimization for Android Auto, go to Settings > Apps > Android Auto > Battery > Battery Optimization, then select "Don't Optimize".
If none of the above solutions work, you can try resetting the Android Auto app. Go to Settings > Apps > Android Auto > Storage, then tap on "Clear Cache" and "Clear Data". Afterward, set up Android Auto again and see if the issue persists.
03-04-2024 04:04 PM in
جالاكسى S
