SMIRSMRN
02-20-2025 02:53 PM in
جالاكسى S
I'm noticing some discussion around battery and charging issues with the S25 Ultra 📱. I've been keeping an eye on my own battery life 🔋 and charging speeds. So far, I haven't personally experienced any problems. Have you found any solutions or helpful I'm experiencing a frustrating issue with my phone: the battery drains incredibly fast, even when it's charging. It's like a bottomless pit! 😩 Has anyone else encountered this problem? I'm looking for solutions beyond the usual tips and tricks. Any advice would be greatly appreciated! 🙏 #phonebattery #batteryissues #techhelp.. Let's share your experiences and help each other out! Join the conversation in the comments below. #S25Ultra #BatteryLife #ChargingIssues
3 Comments
drhatem
02-20-2025 08:14 PM in
جالاكسى S
You can switch off 5G and deactivate always on display
Lokiraju
03-13-2025 08:45 PM in
جالاكسى S
Me too have same issue of faster battery drain despite all battery savings settings done.
nay3f
03-19-2025 11:01 AM in
جالاكسى S
It happens if your phone heats up and higher power consumption apps running in the background also cause a significant effect on your battery life, so you should regularly optimise your phone from device care in settings.
