Samsung s25 ultra battery drain issues
(Topic created on: 10-10-2025 03:18 PM)
hasantbf420
جالاكسى S
I bought my phone a week ago. Then I've been facing battery problems since I opened the phone.Updates come after turning on the phone ui 8.0. Fast i facing heating issues and battery drain issue. Now don't have any heating issue but facing battery drain issues. When i don't use my phone that time also darin battery. Like when i go sleep that time my battery have 100% charge but when i wakeup in morning (i mean after 5-6 hours ) then i see my battery charge have 80-82% . Anyone please tell me how to fix it
6 Comments
fantrokme
جالاكسى S
Sleep is known for battery draining not only in the 25 ultra all the phones don't use sleep and you will be good
hasantbf420
جالاكسى S
hasantbf420
جالاكسى S
I don't use sleeping mood but when i don't use my phone that time also battery drain automatically 🙃
6ar8
جالاكسى S
Enable air plane mod when you sleep and see the result
Shrebbeast
جالاكسى S
😊m
ABinAlhadi
جالاكسى S
I'm using an S24 battery, and phone heat is my biggest issue.
