Samsung S24 Ultra Battery Drain Issue
(Topic created on: 01-20-2025 08:02 PM)
rajeduzzaman
Beginner Level 3
جالاكسى S
Hey,
I got the S24 Ultra two weeks ago, I used to have the S23 Ultra.
The S24 Ultra's battery life is worse, only lasting 6-7 hours.
What should I do?
جالاكسى S
7 SOT is normal with Samsung especially after One Ui 6.1 and their heavily AI features consume more power than previous One Ui 5 and older version.
Note that if you enable, it's going to consume more power.
Some tips might help to to get more juice, it's optional, so you don't need to disable all options
● Disable 5G
● Turn on light mode
● Turn on background usage limits through Device care
● Settings  - apps - you can disable apps you don't use.
