S25 Ultra very high temperature on normal usage and battery drain fast
(Topic created on: 08-18-2025 01:07 AM)
ekassis
جالاكسى S
Galaxy S25 Ultra overheats during 1-2 minute voice/VoIP calls and runs hot at idle, causing rapid battery drain, even with minimal use.
No gaming, no background apps.
Same issue since day one with this as a preorder.
I'm seeking known fix or service replacement.
#s25ultra #battery #drain #overheating #high #temperature
6 Comments
yazan01
جالاكسى S
Since when you bought it?
ekassis
جالاكسى S
10 Feb 2025
yazan01
جالاكسى S
You've waited a bit too much
It may be a Manufacturing problem, you should take the phone to the local authorized agent for Samsung in your country they may help.
ekassis
جالاكسى S
the issue is that they want me to keep the phone for several days with them and there is a possibility they request factory reset
this is not acceptable
yazan01
جالاكسى S
You could make a backup for the data using the Smart Switch app search for it, and you got no other options better than this, you tried anything would help before?
ekassis
جالاكسى S
they should be able to fix the issue without a factory reset
even if the data is backed up with Smart Switch, the recovery after the reset in terms of signing IN and addind my 15 emails is huge
it takes several days since I have 300 apps
what to do with 2 whatsapp numbers
