Not applicable
05-03-2025 06:44 AM in
جالاكسى S
My new s24 ultra battery drain very fast in night time without any usage above 25%..I am facing this issue from 3 weeks anyone facing same issues
5 Comments
aref-thibah
05-03-2025 10:41 AM in
جالاكسى S
Follow this steps
https://youtu.be/68cEQmetaHk?si=1bAS33EASyDIodTR
It is totally safe and no data loss
Not applicable
05-03-2025 06:26 PM in
جالاكسى S
I also do this but no result same as before
aref-thibah
05-03-2025 06:28 PM in
جالاكسى S
Then if you didn't make factory data reset you should do it
This can fix the issue
Not applicable
05-03-2025 06:30 PM in
جالاكسى S
My mobile is new mobile only 20 days older
aref-thibah
05-03-2025 06:36 PM in
جالاكسى S
Try to do settings reset
Also even if you you have new phone some time new update makes some corrupted files
So the format is best solution
