S24 ultra battery drain
(Topic created on: 04-28-2025 06:55 PM)
Ali_Elemam
جالاكسى S
Before the one ui 7 update I used to charge my phone once a day now I have to charge it twice a day, I hope samsung will fix this in the may security patch, one ui 7 is so good, the animations are perfect, and the ai is so much better and smarter.
6 Comments
BEBO_TECH
جالاكسى S
Do a factory reset on your mobile phone and the problem will be solved.
Ali_Elemam
جالاكسى S
Thank you for the suggestion, but I would prefer not to do a factory reset because it would take a lot of time to set everything up again, and I'm worried I might forget to back up something important. I hope Samsung will optimize the battery better in a future update.
BEBO_TECH
جالاكسى S
You're welcome, don't say that. I didn't do that, but the problem won't be solved unless you factory reset the phone. This is the solution. Samsung might also release a security update that solves the problem.
Ali_Elemam
جالاكسى S
Yeah, you're right, but honestly, I just don't trust myself to back everything up properly.
BEBO_TECH
جالاكسى S
God willing, Samsung will release an update that will solve the problem.
hnmmah11195
جالاكسى S
اعمل ضبط مصنع
