S20 plus battery issue
(Topic created on: 11-23-2020 11:36 AM)
minarizk
Beginner Level 4
جالاكسى S
Please advise,
My battery got empty after half a day
I didn't play games or open camera
Is there any one like me
I always use medium power saving
How mush should the battery work in normal case?
I feel its a common issue.
8 Comments
IME2020
جالاكسى S
اكتب عندك في بحث في الضبط battery usage افتحها وتشوف اي برامج الي بتستهلك بطاريه
Bakbakak
جالاكسى S
you cann less the screen resolution to FHD+
Not applicable
جالاكسى S
انا برده كنت شاكك في بطاريتي A71
ورحت التوكيل
في بوست عندي بص عليه ببكشفوا علي البطارية اذاي في التوكيل
minarizk
Beginner Level 4
جالاكسى S
اشكرك علي مساعدتك
انا عملت التست اللي حضرتك كاتبه عندك علي البطاريه لقيته خصم 7٪
دا كدا فيها مشكله؟
minarizk
Beginner Level 4
جالاكسى S
بقاله شهر ونص
Mohamd-Waheed
جالاكسى S
look on battery usage and see if there's a app use too much battery, and if u use the 120 hz it's use too much battery
Amira-elnagar
جالاكسى S
Hello. I’m Amira, Samsung Moderator.
Thank you for asking the question
We wish you a happy day
Based on your inquiry regarding
I ask permission to perform the following steps
  1. Check the Display Brightness
  2. Check if the device spends a lot of time in an area where the phone shows only a weak signal strength (less than two bars)
  3. Exit Active Applications
  4. Check Battery / Power key
  5. Check battery usage with their devices. Go to Settings>about phone>Battery usage to find out all usage
  6. Apply “Power Saving Mode”
  7. Perform Factory Data Reset
 We hope to solve the problem when you come as soon as possible
If you have any other inquiries
You will meet us under your command at any time
Thanks
MishaVish
جالاكسى S
Power saving & sleep mode for apps
