Tiffany876
10-08-2017 05:43 AM in
جالاكسى S
I am having a problem with my s7 edge. When I select a picture for my home screen and apply it,it says for a while then reverts to the pre-programed home screen the phone came with. Also when I'm playing music, listening voice notes or watching a videos the phone keeps pausing as if it was buffering or on pause and I have to tap the screen all the time for whatever I'm watching to continue. Help please!!
5 Comments
GasserAtef
10-10-2017 02:51 AM in
جالاكسى S
it's probably an app you downloaded that's doing all of this. check the apps you downloaded recently and uninatall them and see if the issue is fixed. if not then factory reset is your best option
Tiffany876
10-10-2017 06:03 AM in
جالاكسى S
I tried it and it worked...thanks a million
GasserAtef
10-10-2017 04:15 PM in
جالاكسى S
you're welcome but just for my own curiosity
which one worked? factory reset? or uninstalling the apps?
Tiffany876
10-10-2017 04:25 PM in
جالاكسى S
uninstallation of a couple apps
GasserAtef
10-10-2017 05:14 PM in
جالاكسى S
okay thank you
