11-18-2025 02:31 PM in
جالاكسى S- Mark as New
11-19-2025 11:58 PM in
جالاكسى SDear Valued Customer
Thank you for contacting us,
please try the steps below to fix the issue:
1. Reset Bluetooth on the phone
Turn Bluetooth off, wait 10 seconds, then turn it on again.
2. Forget the earbuds and reconnect
Go to:
Settings → Connections → Bluetooth → Tap the gear next to your earbuds → Forget
Then try pairing again from the Bluetooth list.
3. Put earbuds in pairing mode
Place both earbuds in the case
Close the case for 5 seconds
Open it again → The earbuds should enter pairing mode automatically.
If not, press & hold both earbuds for about 7 seconds until the light flashes.
4. Check SmartThings or Wearable app
If you use Galaxy Wearable, open it and try to connect from there.
Make sure the app is updated.
5. Restart both devices
Restart your S24 FE
Restart the earbuds (place in case → close → wait → open)
6. Check if earbuds are paired with another device
Sometimes they stay connected to a previous phone or laptop.
Turn Bluetooth off on any other device you have used before.
If the issue continues
Please try connecting the earbuds to another phone
If they still don’t connect, the earbuds may need servicing.
Have a great day
Best Regards
Samsung Levant CS team
