My phone Battery condition got Weak. (S7 Edge)
(Topic created on: 11-26-2019 01:36 AM)
Faisalkhan1
جالاكسى S
Hi everyone, I hope you all Doing well. After Few months I open Samsung member apps. Check all of my Hardware Test! 1 of them is Fail the Test which is Battery!
My Battery down to Weak Condition. When I Tap on Faq, They told me
"Whenever the battery Condition reaches to Bad. We recommend to replace your battery"
I am using my phone for 3 Years.
Now one thing make me shocked! My father phone (S6 Edge) is a good Condition!
He is using his one for 3 and half years. This is because he is not using heavy apps... I am not sure how it's work
Ok I wanna ask few questions...
How Much it will cost me to replace my battery in Saudi Arabia?
Where do I replace my battery?
What happen if my battery Condition reach to Bad? (Is it gonna Drain my Battery faster?)
Is there anyway to keep my battery healthy?
Hope you help me 😀
Thank you
5 Comments
ShiShini
جالاكسى S
you can find the original battery replacement every where in souq.com its 80 Sr only the battery so I think it might be around 100+ in Samsung dealer for the price of the battery and procedure of replacement
Faisalkhan1
جالاكسى S
Thank you for info
ShiShini
جالاكسى S
you are most welcome
ImranMansoor
جالاكسى S
Souq.com where you can find good quality products for less expensive than other places around Saudi Arabia
and Souq.com you can trust
ShiShini
جالاكسى S
you can keep battery health by :
first slow down your battery charging cycle
keep it cold
avoid fast changing unless you really need it
