The problem with face lock and camera
(Topic created on: 06-11-2020 06:33 PM)
Hayran
جالاكسى A
Hello ... I have problem with my (Samsung A31) when I put face lock on my mobile the camera doesn't work also the UI system get stop and close until I restar my mobile it will be work... what is the solution...
4 Comments
Not applicable
جالاكسى A
format your device
Hayran
جالاكسى A
I did that, it was useless, i will be wait for software update
Samsung_Expert
جالاكسى A
Dear valued customer
Thank you for contacting Samsung Levant support
kindly note that we shared the issue with the concerned department as there will be a software update released to solve it . meanwhile you can try to remove the face lock until the software update is released
Hayran
جالاكسى A
thank you for response
