04-01-2026 11:54 PM in
جالاكسى A- Mark as New
04-02-2026 12:39 AM (Last edited 04-04-2026 03:19 PM ) in
جالاكسى AHere is a quick checklist to fix the drain:
### 1. Enable "Adaptive Battery"
Go to **Settings > Battery > Adaptive Battery**. This allows the phone to learn your habits and limit power to apps you rarely use.
### 2. Check for "Background Giants"
* Go to **Settings > Battery > View Details**.
* Look for apps with high percentage usage.
* Tap them and select **Limit usage > Put to Deep Sleep**.
### 3. Adjust Display Settings
The A25 has a bright 120Hz screen, which is a power hog.
* **Lower Refresh Rate:** Go to **Settings > Display > Motion Smoothness** and switch to **Standard (60Hz)**.
* **Dark Mode:** Switch to Dark Mode to take advantage of the AMOLED screen, which saves power by turning off black pixels.
### 4. Disable "Always On Display" (AOD)
AOD can drain 1–2% every hour. Turn it off or set it to **"Tap to show"** under **Settings > Lock Screen**.
### 5. Deep Sleep for Unused Apps
Go to **Settings > Battery > Background usage limits** and toggle on **Put unused apps to sleep**.
> **Note:** If your phone is brand new (less than a week old), it is normal to see lower estimates. Samsung’s AI takes about 7–10 days to calibrate to your specific usage before the battery life stabilizes.
04-03-2026 05:33 PM in
04-03-2026 06:11 PM in
04-03-2026 06:20 PM in
04-04-2026 09:54 AM in
04-02-2026 12:41 AM in
04-03-2026 05:32 PM in
جالاكسى A
