09-05-2020 06:38 AM in
جالاكسى نوت- Mark as New
09-05-2020 09:56 AM in
جالاكسى نوتAlso my advice is to use dark mode and limit your functions like mobile data if you currently connected via WiFi, Bluetooth if there is no smart ⌚, etc..
Also keep applications not working on background. All this procedures will keep your battery 🔋 working more efficiently and avoid heat 🔥.
I'm sure that not the way to treat with a flag ship mobile but its a temporary way till software issues fixed.
GOOD STUFF
Bold attractive design
Great camera system
S Pen is best-in-class
BAD STUFF
Mediocre battery life
Inconsistent heat management
Palm edge rejection issues
09-05-2020 04:28 PM (Last edited 09-05-2020 04:39 PM ) in
جالاكسى نوت
09-05-2020 11:13 PM in
جالاكسى نوتHello. I’m Amira, Samsung Moderator
we thank you for asking your question
Based on your inquiry regarding for drain battery issue ,
I ask your permission to do some steps:
- Adjust the screen brightness
- Whenever the network is weak, all that the phone is used to exert effort and make the network stronger, then it withdraws from the battery
3- Close the open applications
4- Make sure that there is no problem with the device’s battery or the power button
6- Use the device's original charger
They are at your command and at your service at any time
Thank you for your time
09-06-2020 01:16 AM in
جالاكسى نوتالموبايل مبيكملش يوم
09-06-2020 02:02 AM in
جالاكسى نوتKindly We ask you to supervise us in the maintenance branch
to check the device and help you solve the existing problem
To find out the nearest maintenance center to you, I ask you to enter the following link
We hope that the problem will be solved at your presence as soon as possible
09-18-2020 06:57 PM in
جالاكسى نوتthe mobile is getting heated severely and I had to replace it with another one
the second is getting heated too
should I get my money back and forget about note 20
09-20-2020 02:13 PM in
جالاكسى نوتHello. I’m Amira, Samsung Moderator.
First of all, I feel sorry to hear that you have experienced the anomaly
Thank you for asking the question
We wish you a happy day
Battery is drained rapidly and device is overheating
Samsung Daily application may cause the sudden battery drain and device’s overheating.
According to this, Samsung released an improved version to address issues of Samsung Daily application.
to the latest version(V4.2.02.01 or later) from Galaxy Store.
After updating, please restart your device.
Thanks for your time
