09-15-2020 12:04 PM in
جالاكسى نوت- Mark as New
09-15-2020 12:20 PM in
جالاكسى نوتThank you for contacting Samsung KSA
battery consumption will increase when you use certain features or apps , such as GPS,games, or the internet
so make sure to close all the apps after you finish using the device
make sure that power saving mode is enabled
check the battery drainage for each app by going to settings-device care - battery
as you can put unused apps to sleep by going to settings-device care-battery-tap 3 dots -tap on sleeping apps -add the apps you want
also kindly visit the nearest service center
the link of the service centers :
https://www.samsung.com/sa_en/offer/service-centers/
Hope you and your family staying healthy and safe!
