Samsung note 10 plus battery drain
(Topic created on: 04-28-2021 04:52 AM)
Scarface79
جالاكسى نوت
After the latest Android and UI update, I'm seeing a lot of battery drain even with normal use, the battery went from 100% to 66% in less than 3 hours. My phone is up to date,  I shouldn't but the battery on saving mood all day! That's not acceptable at all, there must be something can be fixed within the software.
kitsune2708
جالاكسى نوت
Your apps
Check your apps
Its not the software and besides the note 10 battery is not big
