Looking for a solution for my problem
(Topic created on: 02-16-2024 10:51 PM)
wsinjab
جالاكسى نوت
I am facing a problem with my mobile phone S22 Ultra. Wi-Fi, Bluetooth, and mobile hotspot features are all disabled or not working properly. My device does not connect to any other device. I upgrade to the latest software but still the same.
5 Comments
aliatta123
جالاكسى نوت
Remove sim?
wsinjab
جالاكسى نوت
So what
You mean I have to remove the sim an check
KhalidAA
جالاكسى نوت
In the Settings, search reset and tap on the setting
Reset Wi-Fi, mobile & Bluetooth
wsinjab
جالاكسى نوت
I do it
But still the same
KhalidAA
جالاكسى نوت
Try to do factory reset . If the problem still this means you have hardware issues, not software
