JubinBos
05-26-2025 01:21 AM in
اخرى
After the UI 7 update, my phone is showing battery issues. For normal use, it only lasts 4 to 5 hours maximum. Also, fast charging is not working, it takes at least 1.55 hours to charge from 0% to 100%. Does anyone know of any solutions? Are other users experiencing this as well?
3 Comments
marsool
05-26-2025 01:31 AM in
اخرى
No, there's no problem with the battery. I'll show you how to fix it from the settings.
1 - Turn off the 5G network.
2 - Go to Settings - Battery - Background Limits - tap the three dots above - Adaptive Battery and enable it.
3- The same steps, but click on the applications in deep sleep mode and put any application that you do not use in sleep mode.
4 - Go to step 4 and click on battery protection and set the maximum charge to 80% and it will stop automatically.
5 - Delete as many apps, photos, and videos as you can.
6 - Do very fast charging from settings
Once you've completed all the steps, turn off the device, turn it back on, and charge it until it stops charging. Then, start using it. You'll see the difference.
Samsung batteries are generally fatigued, but...
JubinBos
05-26-2025 01:45 AM in
اخرى
Thanks for the advice.
These are the first steps for beginners, and I have been using my phone for 1.5 years in the best way. And there were no issues.
I already mentioned that, after the UI 7 update started these were all issues.
أبوطلال-
05-26-2025 07:28 AM in
اخرى
I think based on these symptoms, you may consider changing your battery, apparently you battery is no longer sufficient to meet stander usage
