Highlighted
My iconx green lights are not turning off and ar draining battery eventually
1 التعليق
Highlighted
we recommend you to try to check for available software updates for your galaxy buds and try to reset them , if you faced the same issue then service is needed as we recommend you to refer to the nearest service center in your country to check your device by a samsung techniican
to get service locations go to
www.samsung.com/le >> choose your country > support > service locations
رد
جارٍ التحميل...
