Samsung Fit 3 Faulty Sleep Monitoring and Quick Battery Drain
(Topic created on: 07-23-2025 08:56 AM)
ahtshampk
أجهزة قابلة للارتداء
The Samsung Fit 3 band has a faulty sleep monitoring. Every morning, I have to delete my sleep record and enter the sleep time manually.
When is Samsung going to fix this faulty sleep monitoring in Fit 3?
The other issue I have noticed that contrary to the Samsung claim of 13 days battery life, the watch battery drains in four days on normal usage, including the wrist gesture screen-on, heartbeat and stress monitoring.
If all the above options are turned off, the battery lasts for 7 days.
Previously, I have used Samsung Fit 2 for two years, and its battery last for 12 ~ 13 days with wrist gesture screen-on, heartbeat and stress monitoring.
I switched to Fit 3 from Fit 2 because I was not happy with Fit 2 faulty sleep monitoring but Fit 3 sleep monitoring is worse.
6 Comments
نهن عا ٧اصة٧ا ٧ىة
معا غب صعاص ٧اةخلب
متتيتع غي تصقخفر غب عفي
مغل لص ص ياسر غقث هثسة غسك٦ثس ةق
عصر خقث
