lem198524
Beginner Level 4
Good day, any help on my samsung s7 edge battery drains fast even replaced new battery.. thanks
5 التعليقات
Kuzco69
Contact their customer service. I had a similar issue and they replied. See if your device has some sort of faulty hardware which in this case you can return to them.
رد
جارٍ التحميل...
phantom2
Expert Level 3
define fast. how many hours. define how you use your device gamming YouTube vedio etc
رد
جارٍ التحميل...
ImranMansoor
everything depends on how you use your phone
if you play games continuously for long period, battery will drain
small tips is use dark mode on your device
remove unwanted and unused apps from your device
رد
جارٍ التحميل...
lem198524
Beginner Level 4
and now innoticed my phone shots down by it self.
رد
جارٍ التحميل...
lem198524
Beginner Level 4
its already out of warranty since it was an old model, i want to know it samsung service centers still doing repairs for s7 edge models.
رد
جارٍ التحميل...
